Posted by RedJohn-2 on November 03, 2008 at 18:41:45 from (70.119.35.69):
In Reply to: Model M manual posted by Buck Wayne on November 03, 2008 at 13:16:01:
Buck Wayne, If you have a 3-point hitch on your M, it is either after-market or home made. Saganaw and Worksaver both sell 3-point hitch for M. These hitches can be ordered with either two cylinders or one cylinder. The Worksaver that I have on a H has two 3" cylinders. I copied that one, using two 4" cylinders, to install onto my M. The amount of weight you can lift is a factor of the size of your cylinders X pump. (I am assuming you are using the factory belly pump). My M with the 4" cylinders will lift much, much more than the H with the 3" cylinders will lift. Both my H and M will lift a 1200 lb bale. Your problem will be keeping the front of the tractor on the ground. Front wheel weights and even more weight will be necessary; but, don't get too carried away with weights...tractors have been broken in half by over doing it. (Although usually with a front end loader rather than rear lift). Also be prepared to steer by using your brakes. If your hitch only has one cylinder you may have to add another cylinder onto your hitch. Just install it on the opposite side from your existing cylinder. I think the lift capacity is determined by some mathematical factor of pump X cylinder(s). (The bigger the cylinder the more you can lift). Somebody here will know. I like Binder Books for manuals.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
