Re: Gas vs. Diesel revisited
Posted by caterpillar guy on November 04, 2008 at 03:27:07 from (64.12.116.73):
In Reply to: Gas vs. Diesel revisited posted by Jason from MI on November 03, 2008 at 14:49:05:
If your going to work that 574 in the field much in a utility model they are hot to use. Your setting right on the transmission housing and it gets hot from the oil running through the lines front to back and in the transmission with the gears turning. I would opt for a 300or 560 if in the field. Otherwise a good tractor for tight places. There is a heater that will go in the bottom radiator hose that works good for winter starting. As for the fuel unless you get a big supply in the summer and don't use it before winter the blend thing will already be done by the fuel supplier long before you get it. Dad bought that model new in 1972 and it is still on the farm with a loader on going every day.
