Re: 460 coil wires
Posted by iowa farmall on November 04, 2008 at 05:12:31 from (66.43.214.78):
In Reply to: Re: 460 coil wires posted by John T on November 03, 2008 at 07:12:59:
There were two wires on the coil high input side. The switched voltage wire and this mystery white wire. The tractor has a 12 volt coil and is running 12 volt negative ground it has a generator. I do not know if this is how it started it's life. It has been around the farm for a long time but not hardly used until this summer I took an interest in it and am trying to get it tuned up. It is a good running tractor and everything is pretty much original but the original voltage could be a mystery.
