Posted by JD in Wanchese, NC on November 04, 2008 at 06:28:47 from (71.80.52.106):
the lift on my 574 d "hic-ups" when under load. i have changed hyd oil and filter...no change. it does this worse when the oil gets hot. according to the repair manual it could be a scored cylinder or ring problem, a cylinder cushion valve leaking, or a drop poppet issue. cushion valve is under the seat in the top cover. i have a dimantled 648 in my shop that i was "exploring" before i take the 574 apart, and the cushion valve does not come right out. it appears to be in a threaded bore but will only turn about 1 full turn. is there a procedure i am not doing or do i need special tools? the repair manual does not say. any help would be appreciated. Thanks, Jonathan
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
