Re: Loosener Preference
Posted by mkirsch on November 05, 2008 at 05:24:52 from (64.80.110.50):
In Reply to: Loosener Preference posted by Wayta on October 31, 2008 at 14:06:41:
People don't use penetrating oil properly, and don't understand how it works.
They spray a bolt, slap on a wrench, and if it turns, boy oh boy that Whizbang Blastoil is great stuff!
Twist off the bolt, and man oh man that stuff is crap!
News flash: If that bolt turned, it wasn't because of the penetrating oil. It would've come all by itself.
Take a look at that bolt you just sprayed and removed. There is little or no penetrant on the threads where the nut covered them. They're mostly dry.
Penetrating oil takes TIME to penetrate. If you don't give it time, it won't do you any good.
