Need Help
Posted by NC Mike on November 05, 2008 at 09:32:27 from (68.221.82.209):
Have 52 Super M. I think it has a M motor in it. The S/N number is FBKM 190412 and and a casting date of 6-24-S. Also stamped 6722-DJ. The head is marked inside the valve cover 8060-DC with 1-X above it. My first concern,I pulled the rocker arm assembly to check the torque on the head. I also pulled the push rods to inspect. When I pulled one I guess I lifted to quick and pulled the tappet valve out of it"s hole. Can I just pull the side plate to reinstall? Second question is the breather tube is missing. Should it be reinstalled? Would this explain the white scum on the top of the inside of the valve cover? The oil in the engine does not show any signs of anti freeze or head leaking.
