Re: exhust lift of Farmall A
Posted by Gene Bender on November 05, 2008 at 17:24:18 from (67.55.226.167):
In Reply to: Re: exhust lift of Farmall A posted by Wayne Gampp on November 05, 2008 at 07:38:40:
The hose from the valve assy by the filter goes to the cycl from the out ward port on top of the valve. Heater hose works fine. The inword port goes to the pressure valve on top of the manifold. This should be pipe. The hose goes to the bottom of the cycl. The pipe plug in the front of the cycl is to bleed the system in the winter as there will be moisture and an oily mix in the bottom of the cycl. That mixture comes from condensation from the exhaust. I also keeps the leather soft and helps it to seal. If the sysl is not used in the winter draining is not necessary. A few squirts of oil added in the breather plug where the brace supports the top of the cycl also keeps the leather in good shape.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
