Re: Has this ever happened to you?
Posted by Duner Wi on November 06, 2008 at 17:42:35 from (63.27.179.46):
In Reply to: Re: Has this ever happened to you? posted by Dr. Bert on November 06, 2008 at 16:57:01:
Check compression on bad push rod cyl. when you put it together. I am wondering if you could have a sticky valve due to carbon build up on stem.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
