Re: 1086 Hydraulics
Posted by JayIHMan on November 06, 2008 at 19:24:02 from (70.243.239.103):
In Reply to: 1086 Hydraulics posted by Tom in Michigan on November 06, 2008 at 18:22:33:
Yes on the bottom of remote valves, there should be a removable expansion plug. Using a flat screwdriver turn slotted screw inside of housing in to desired detent setting.
