Farmall Tractors Discussion Board
Re: Re: Farmall M - 12 V conversion
Posted by Don H. on December 22, 1998 at 15:54:04:
In Reply to: Re: Farmall M - 12 V conversion posted by Woody on December 22, 1998 at 13:35:48:
I don't know which of the several varieties of engine heaters you may be interested in, but one of the simplest is installed in the lower radiator hose. Just cut the hose, install the heater, put the clamps over both ends, and re-install the hose. They are inexpensive and work well. There are other varieties too, so pick the one you like best and go with it. Good luck with your tractor.
Post a Followup
: Re: Re: Re: Farmall M - 12 V conversion
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
