Re: Super C mounted plow
Posted by Hugh MacKay on November 07, 2008 at 03:30:38 from (216.208.58.182):
In Reply to: Super C mounted plow posted by Larry Ralston on November 06, 2008 at 20:15:07:
Larry: It sounds as though you have some parts missing. Problem with these plows after 50 years, is much of the mounting hardware comes off, one piece at a time. Grandpa had a place he hung it all in the barn, then there was the odd part he had another use for. Grandpa passed away, and folks selling the estate missed some of those pieces.
Your best bet is find a parts diagram, then you can sort out what you have or don't have. Fabrication will be a possibility, as very likely what you have missing is steel flat bar, with a few holes drilled in it.
I don't know the model numbers for C and SC plows, however if they are like other IH implements there was an A, B, C, H and M version. There is an A-295 two bottom plow, diagnol cross members between plow beams. I think we can assume there is a C-295 two bottom plow. It's a start, go to CaseIH parts online, and look for C-295 plow, watch for any other C-xxx numbers.
If you happen to live in Canada, it could be a 212, difference is cross members between beams are perpendicular.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
