Re: 1086 Hydraulics
Posted by Brownie 450 on November 07, 2008 at 07:19:03 from (216.51.158.151):
In Reply to: 1086 Hydraulics posted by Tom in Michigan on November 06, 2008 at 18:22:33:
Did you try reversing the hydraulic hoses in the remote outlets? My nephew had similar trouble & the remote lever was set for plowing with the float position set on the lever. I cranked the stop bolt down a couple of turns, & the lever locked in O.K. May be your problem. Worth a look.
