Well the easiest way of course is to get the original IH setup for it. This involves changing the draglink to the one with the cylinder also there is a mounting bracket for the end of the hydraulic ram. Than you also need two steel lines, one provides oil from the pump, the other returns the oil to the remote valve assembly using a special fitting. And than there are two hoses to connect the lines to the valve potion of the cylinder. And the other piece you need is the biggyback pump that mounts on the main hyd pump in the transmission. Thus providing the steering sector with oil in priority over the valves.
#19 is the main hydraulic pump and #25 is the piggyback pump that is added to it. Also the bracket you would need is #12, 35 only apllies to the 660
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
