Re: Before I buy this tractor . . .
Posted by bc on November 07, 2008 at 14:47:04 from (70.130.55.114):
In Reply to: Before I buy this tractor . . . posted by Jason from MI on November 07, 2008 at 07:29:36:
Maybe you can get a mechanic to do it on his own time for much less money. Go out and ask one.
I'm not sure you can truly test one till you go out, hook up a disk or plow, put it in the ground, pull and all gears trying the TA etc.
A flow test may tell you that there is some wear and tear on the hyd pump but not how it will work. With an implement on, you can test the hydraulics, transmission, and figure out if the engine can pull a load. Hook up a mower to check the pto. Drive and check the brakes. Drive it down the road in road gear.
No honest farmer should stop you from doing these tests.
