Dude it sounds like you have water trapped in a bearing or the brake housing. If your IH 504 is like my Farmall 504 the brake disks are directly tied to the pinion shaft. If you have moisture/water in the housing/cover that would definatly cause one side to "lock up". I find this more likely than an axle bearing. Pull the RH brake cover and inspect. If water has been there, clean it all up good and silicone the cover when reinstalling. Also make sure it has the rod boot installed as well as in good repair. Those little boots cause me a lot of grief before I replaced mine. Good luck.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
