Re: 6 volt charge
Posted by bcarter2 on November 08, 2008 at 14:04:27 from (74.14.106.230):
In Reply to: Re: 6 volt charge posted by bcarter2 on November 07, 2008 at 14:34:36:
Well my satisfaction with getting this running was short lived. 1 day after, I ran the tractor again, and she wasn't charging. Put a jumper over the Gen/Bat on the Cut out relay and she started charging. So, would it be a good guess the relay is pouched ? If I have to get it replaced, should I go with a voltage regulator or another cutout relay? I have the 4 position switch, would this matter if I use a voltage regulator ?
Thanks.
