Re: Tractor been setting for 10 months
Posted by Andy Motteberg on November 08, 2008 at 19:42:39 from (4.143.222.134):
In Reply to: Tractor been setting for 10 months posted by Gary Sedalcek on November 08, 2008 at 18:10:52:
Put in fresh fuel and make sure the magneto/distributor points are clean. It would also be a good idea to change the engine oil and filter as Armand mentioned below. If you don't rebuild the carb, open the petcock or remove the drain plug on the carburetor bowl and make sure there is fuel getting into the carb bowl. Good luck and post here when you get it running or if you have more questions.
