Re: stop control collars for hyd cylinder
Posted by too many interests on November 09, 2008 at 08:48:02 from (70.48.101.173):
In Reply to: stop control collars for hyd cylinder posted by LMack on November 09, 2008 at 08:03:35:
hi there
At home we use the same set up for our oliver 1850 for the loader. If we need a set of remotes for something we tilt the bucket all the way down so there is not pressure on the lines and unhook those remotes so we can still raise and lower the loader
hope this helps
chris
