Posted by Marv on November 09, 2008 at 09:41:37 from (75.105.128.37):
In Reply to: SUPER MD WIRING posted by ERIC FOX on November 08, 2008 at 17:06:56:
I have a SM diesel and the correct starting procedure is to have the compression lever forward to start. A definite "click" will be heard as the lever goes forward. This action changes the compression over from diesel to gas. The hand throttle show be lowered also.
As the engine starts, leave it run on gas for a few minutes.
To change from gas to diesel, pull the compression back and immediately advance the hand throttle up far enough to keep the engine from stalling.
Always allow the engine to cool the engine before shutting down and always shut the tractor off in the diesel mode.
To shut the engine off just simply lower the hand throttle.
Note: For the engine to run on gas, it needs current to the distributor so the the pull button must be pulled out. I push mine in after the tractor is running on diesel. Good luck.
One last comment> I have observed farmall 400 and 450's diesels start with the compression lever just opposite that of the M and SM diesel's.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
