Re: stop control collars for hyd cylinder
Posted by mkirsch on November 09, 2008 at 10:37:37 from (67.240.251.254):
In Reply to: stop control collars for hyd cylinder posted by LMack on November 09, 2008 at 08:03:35:
Jerry, unless you have an odd loader, the bucket cylinders extend to tilt the bucket forward. Limiting collars wouldn't do anything but keep you from rolling the bucket back all the way.
For them to work the way you intend, you would need to put the stop collars INSIDE the bucket tilt cylinders somehow.
All is not lost, though.
Simply roll the bucket all the way back, set it on the ground, and float the bucket control on the tractor. Now you can disconnect the bucket and tie the hoses back so they won't drag in the dirt.
Unless there is a major leak somewhere, the bucket will not move when you lift the loader. To reattach the bucket hydraulics, simply put the bucket back on the ground to relieve the pressure on the hoses.
