Re: stop control collars for hyd cylinder
Posted by mkirsch on November 09, 2008 at 10:47:52 from (67.240.251.254):
In Reply to: stop control collars for hyd cylinder posted by Janicholson on November 09, 2008 at 08:03:35:
Oh, sorry. I misread your original post.
Backhoes have "transport locks" that hold the loader up for maintenance or transporting on a short trailer where the loader hangs over the bed of the dump truck.
It's a simple u-shaped piece of steel that fits over the extended cylinder shaft and braces between the end of the cylinder tube and the base of the cylinder. I'd recommend you make a pair of these whatever length holds the loader at a reasonable transport height. Don't forget some way to prevent the locks from popping out. The same technique will work to disconnect the lift arm hydraulics as the bucket.
