Re: Do all 10-20s have the same manifold?
Posted by spiffy1 on November 09, 2008 at 10:53:00 from (70.41.137.72):
In Reply to: Do all 10-20s have the same manifold? posted by Bill Thompson on November 09, 2008 at 07:00:12:
Old-F20 said: and if i recall correctly, from 29 on they exited right at the bottom rear corner of the hood shet, and not back through the 'firewall' to an elbow.
your looking for a manifold that is identical loking to a 22-36 with a switchable heat exchanger. IHC parts book lists this as part number 1714DX, used on serial numbers 139067 and up :D
I'm not familiar with "robin" as rustred noted. Was this an aftermarket brand? I just assumed all the manifolds field adapted through the hood [rather than the stock through curtain, or earlier, firewall] were IH part numbers intended for either F-30s or power units.
Did any 10-20s or 22-36 ever leave the factory with updated manifolds or governors? I didn't see it, but a neighbor said that he seen a modified 22-36 at a show that looked factory and the owner claimed it was. I suspect more likely 'dealer modified' if this was the case [rather than a previous owner very meticulus in sheet metal skills] at all, but I've been wrong all too often before!
