Re: stop control collars for hyd cylinder
Posted by charles todd on November 09, 2008 at 11:22:17 from (205.242.95.138):
In Reply to: stop control collars for hyd cylinder posted by Jerry Gilliam on November 09, 2008 at 08:03:35:
While I was writing my last post I see there have been some replies. If the loader leaks down with the lines disconnected and you do not want to add in a valve then there is only one solution. REPACK your cylinders, they are LEAKING. If the cylinders are tight, then they WILL NOT leak down. They would stay up indefinatly if there were no leaks or bypassing seals.
Good luck, Charles
