TMI, a couple of pics from my SA, which had a Pesco pump, if yours is similar to mine. The arrow is pointing to the part of the body that contains the O-ring or seal (some had one, some had the other) that keeps the hydraulic fluid from escaping forward into the engine.
In the second pic, the shaft with the arrow goes through the front part of the body, and the important 0-ring-or-seal sits around this shaft. and is within the bore in the body.
I had to scrape paint to find the numbers on the pump, but IH has a rebuild-kit (you can see part of it to the left) and they are specific to certain pumps.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
