Posted by JimB2 on November 09, 2008 at 18:49:16 from (99.241.179.24):
In Reply to: Re: IH 574 weirdness posted by Jason from MI on November 09, 2008 at 17:17:38:
Jason, Sometimes it is just a broken parking brake cable. Symptom is parking brake lever pulls to the top with no resistance. The bad parking brake band is parking brake appears to lock on but will not hold tractor on incline. If the parking brake hasn't worked for years then there probably will not be a problem as the chewed up parking brake bits have all been trapped in the hydraulic filter or settled to bottom of transmission. My brother had a summer student working for him one summer and he drove his 684 with parking brake on and that was at least 10 years ago and has not suffered in permanent hydraulic damage. He did change the hydraulic filter more frequently for a while. His solution was to install an eye bolt through floor board and between the two brake pedals and to lock brakes on he puts a pin in the eye of the eye bolt. I don't believe this set up would pass safety standards as parking brakes are supposed to be mechanical only and not rely on hydraulics.
The smell for Diesel fuel in crankcase oil is to see if the front lip seal on the Bosch fuel injection pump is leaking Diesel fuel into the crankcase. This is caused by the new Ultra Low Sulphur Diesel fuel not having sufficient lubricity to lube the older injection pumps. The seal is only $8.00 but have to remove injection pump to replace. The problem can be avoided by adding Diesel fuel conditioner or a tablespoon or so of crankcase oil to the fuel tank everytime you fill the tractor.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
