Posted by John T on November 09, 2008 at 19:37:51 from (66.244.97.31):
In Reply to: Gen light question posted by Brian in Ne on November 09, 2008 at 19:05:02:
I dont have any wiring diagram for that tractor, but if its a generator with a voltage regulator I can tell ya this. If one side of the light were wired to a switched voltage source like say the ignition switches IGN output (or equivalent point) so its hot ONLY when the ignition is turned on,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,and the other was wired to the GEN/ARM terminal on the VoltAGE Regulator,,,,,,,,,,,When you turned on the switch prior to the engine running the light will burn cuz it gets a ground path via the gennys armature but then once running iffffffffffff the genny is working the light would go out.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
