Re: 706 - add third hyd valve?
Posted by charles todd on November 09, 2008 at 20:00:07 from (205.242.95.138):
In Reply to: 706 - add third hyd valve? posted by Doug - Iowa on November 09, 2008 at 19:37:32:
Very easy... All you have to do is get another "sandwich" valve and place it in with the existing. It will require replacing the 3/8" mounting bolts with longer ones. Also one would have to find or modify existing pivot rod for the lever.
I have 4 valves (open on both sides) and 3? handles. I also have 2 bypass endcaps. If interested, I could sell one as is (as is) or rebuilt (I'll stand behind it). The last two I rebuilt I bead blasted all parts for the detent operating assembly, replaced all o-rings, detent balls, and unlatching pistons.
Somewhere I may have some banjo fittings and bolts, but I would recommed using 5/8" (-10) ORB fittings instead. I used ORB to JIC and rubber hydraulic hose.
Here are some pics of the valve you need, I think. They are good for a 404-1486???
INSTALLED
third party image
REBUILT
third party image
PAIR OF THEM
third party image
Let me know if I can help, these valves can be hard to find.
Charles
