frozen bolts on Farmall 560
Posted by Gary Hutchinson on November 10, 2008 at 09:19:14 from (192.236.23.184):
I need to move my rear wheels out a couple inches on both sides to accomodate a cab. I got
one loose and slid out with no problem using a
1 5/16" box-end wrench. On the other side, the
two bolts on the tractor side loosened without
much trouble but the two on the outside won't
budge. Clearance is a little limited because of
wheel weights. I think I can remove it OK with a little effort although it is rusted in place also. Anyone have a proven method for loosening
those big bolts on the wheel hub?
