Posted by JimB2 on November 10, 2008 at 14:30:03 from (99.241.179.24):
In Reply to: IH 574 weirdness posted by Jason from MI on November 09, 2008 at 14:33:57:
Jason, another simpler cause could be the STOP/START/RUN control cable. Did the owner explain the the START position which is about 1/4 the way up. For first start of the day put the lever in the START position start the tractor let it run on START for 15 to 30 seconds then pull lever all the way to the top to the RUN position. Also check the fuel control lever on the side of the inject pump that when the STOP/START/RUN lever is in the RUN position the lever is fully forward against the power control adjustment screw. Sometimes the STOP/START/RUN control cable slips on that holder screw and doesn't push the fuel control lever all the way forward and this will reduce the fuel flow to the engine and HP developed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
