Re: old block repair weeping:
Posted by charles todd on November 10, 2008 at 15:44:55 from (205.242.95.138):
In Reply to: old block repair weeping: posted by 1938 F20 on November 10, 2008 at 15:06:35:
Interesting topic... I have a 1962 Farmall 504 with the D188 in it. At one time, probably in the late 60's to early 70's (before we got it) it threw a rod. Engine was rebuilt and the pieces welded back in. They used some sort of silver coating on it inside and out. It weeps pretty good and keeps side of the block wet, though does not cause oil level issues.
I have wondered if when (if ever) I rebuild the engine if I should grind into the weld and use a cast or 308L stainless rod to reweld the patch. It has some porisity and I think the "wormholes" are the leak path. It would be nice to apply an epoxy to it.
Charles
