Re: What is ATF
Posted by Bernie Steffen on November 10, 2008 at 16:00:47 from (12.205.165.134):
In Reply to: What is ATF posted by Mike Farmer on November 09, 2008 at 23:55:21:
Everybody has a solution to freeing a stuck engine. I have good luck,fill the cylinder with atf,Make a fitting for the sparkplug hole, use a grease gun. Have to loosen the valves so they are closed. Works for me. Have also used hydraulic pump from another tractor. Bernie Steffen
