Re: carb settings
Posted by ScottyHOMeY on November 10, 2008 at 16:39:22 from (70.105.230.210):
In Reply to: Re: carb settings posted by Josh Watson on November 10, 2008 at 16:00:01:
third party image
third party image
The construction of that arm on the right side isn't such that it would bend out of shape under any stress on the system in any way that would affeect it's forward/reverse functional operation - basically a flat bar, so likely isn't a problem. It does have an offset lef to right, but is otherwise a straight bar on the input shaft. I can't get a picture of it straight on. The governor housing obscure it from the right, and the generator and belts and pulleys from the left.
Here's some pics. The first is on my BN, the second is on my Super C (same setup, as long as your A is above that serial number 2690).
[I'm borrowing a friend's site to post these, so they'll disappear from his server in a couple of days. If they are of any use to you, best to copy them now!]
