Re: old block repair weeping:
Posted by screwstick on November 10, 2008 at 16:54:25 from (75.91.103.198):
In Reply to: old block repair weeping: posted by 1938 F20 on November 10, 2008 at 15:06:35:
Drill the ends of the cracks to keep them from 'growing'. After a crack has been 'fixed' with JB weld, brazing, silversolder and such, it cannot be welded at a later date because of the material contamination. Think long and hard before doing some of these fixes. In your case, I determine the material used for the fix and then plan accordingly. Many times you can drain out the 50/50 mix and go to straight water. The water will allow the cast to rust and the rust will seal up the crack. Then go back with the 50/50 mix. Good Luck.
