Re: Draft control??
Posted by Allan In NE on November 10, 2008 at 17:03:09 from (148.78.243.26):
In Reply to: Draft control?? posted by Draft control on November 10, 2008 at 16:00:39:
I've never owned an 86 model, but I'll try to give ya a "generic" explanation. :>)
The draft will work on any job that is ground engaging and with implements that are 3-point mounted. It sets the “depth or load” of your work and I’ve used it on everything from plows to cultivators.
Your position control should have a “run” position; this is where the position control should always be after lowering the implement.
“Light” on the draft control lever is shallow; “Heavy” is deep. Once you get your depth set, leave the draft control in this same position (unless you wanna change the depth).
Use the position control to lift and lower the implement and the hitch will always find that same load or depth that you’ve set the draft to.
Hope this makes sense,
Allan
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
