Posted by glennster on November 10, 2008 at 17:07:37 from (68.60.242.156):
In Reply to: Farmall H Steering posted by Diggerdan56 on November 10, 2008 at 15:47:01:
its not adjustable per se. you will need to find out whats loose. take the hood and grille off the tractor, then start at the steering wheel and work dow,. check the u-joint by the gauges, see if its tight. then pull the cover off the top of the steering bolster and watch the worm and sector gear as you turn the wheel. more than likely there is where your slop will be. if the sector gear is a full circle gear (the gear connected to the bolster, not the steering wheel shaft) you can remove it and turn it 180 degrees. that will tighten the steering up some. other areas are the bearing at the end of the steering shaft( under the pipe plug cap at the top of the bolster) the bolster bushings could be worn, or the lower bolster bearing. if you need to rebuild the bolster, carter and gruenenwald sels the whole kit, bushings, bearings and seals for about 160 dollars.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
