Posted by Janicholson on November 10, 2008 at 19:57:31 from (66.173.50.147):
In Reply to: clutching issues on H posted by c1802362 on November 10, 2008 at 18:53:38:
Make sure you lubricate the pilot bearing in the center of the crank shaft. Lining up a pulley mark that is not the timing mark, with the timing pointer will allow access to the zerk fitting in a access hole under the clutch housing. Ypur manual will explain. If your trans mission is very low on fluid (80-90 gear oil) it will also contribute to the issue, or if the gear oil was replaced with Hytran. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
