Try this if it fixes it you know what the issue is. Use a different 12 volt battery to provide ignition voltage. (take the wire coming from the switch off of the coil. and hook a battery up with jumpers to the coil, and ground (same polarity as the regular battery) then try to start it using the regular battery. If it starts right up, the issue is voltage drop to the coil when cranking. Heavy o gauge battery cables might make it fire, or a 12volt coil designed for use with a external ballast resistor. If you choose the new coil, you need to put a single pole switch across the ballast resistor so you can manually take the resistor out of the circuit when cranking, then put the switch to off allowing the resistor to be used. If you are volt meter friendly, the coil needs 10 volts for enough energy to fire when cranking. If it is less it will be difficult to start. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
