Re: 706 injector pump
Posted by Allan In NE on November 11, 2008 at 02:44:28 from (148.78.243.24):
In Reply to: 706 injector pump posted by allnightshifter2 on November 10, 2008 at 20:14:45:
It can't run without a fuel bypass/return.
Sounds like someone has done a two-bit repair by removing the vent and now the debris has probably plugged the line somewhere on downstream.
Allan
