Re: Super C Gear Problem
Posted by Gene Bender on November 11, 2008 at 05:03:30 from (67.55.226.167):
In Reply to: Super C Gear Problem posted by Dennis R on November 10, 2008 at 17:41:08:
You must not have had the shifters all lined up in neutral. You can try to pull the shifter lever and line them up. But if the shifting forks arent lined up you will have to pull the tranny top to get them in position so they will line up on the groves that move the gears. My guess is the forks arent lined up.
