Re: milky oil
Posted by Janicholson on November 11, 2008 at 06:08:57 from (66.173.50.21):
In Reply to: milky oil posted by Stan Bainter on November 11, 2008 at 05:53:39:
Because the coolant is getting into the pan, pull the pan and look for leakage around the base of the cylinder spigots (where the pistons disappear) and other areas. If it seams to come from the spigots area, it will need to have the seals redone in that area, or look for a crack in the block there. If it comes from above and is in the front cover area, or a drain to the pan from the head, it is possibly a gasket issue, or crack in the waterjacket. Was it a running engine before overhaul, and was the head given a crack check? JimN
