Posted by Wild Bill Caldwell on November 11, 2008 at 06:48:30 from (67.33.119.9):
Thanks for the help so far...Exploded diagram of a Wico X shows a rotor with what appears to be gear teeth on the outside (Rotor was missin'when I got into this Mag.) Lookin'at the magneto seems to be a gear drivein' the rotor, rotor spins on a shaft on a bar that runs across the magneto body...Bear in mind I've been timein'engines since the first Model A Ford I bought in the mid 50s, I don't claim to be a mechanic, I know to get # 1 cly TDC compression stroke, timein' marks lined up and start from there. Question is, since this rotor doesen't have a flat spot to match up with a flat on the shaft, (I haven't got a look at a rotor yet, may have ask too soon) what clue do You have as to how to get the rotor in the right place the first time, seems like it would be easy to be off several gear teeth.....The mag has what the book calls a window altho I can't see thru it....might need cleanin...Thanks for the help
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
