Re: HYDRAULICS ON H DON'T WORK
Posted by mkirsch on November 11, 2008 at 09:28:51 from (64.80.108.53):
In Reply to: HYDRAULICS ON H DON'T WORK posted by 686142 on November 11, 2008 at 07:55:39:
Just in case: First, the hydraulcs won't work with the clutch pedal pushed in. They are driven off the transmission. Put the tractor in neutral and take your foot off the clutch pedal.
Did the hydraulics ever work? Unless you put in 140W gear oil, you should get at least SOMETHING out of the system even if you used the "wrong oil."
What oil did you use? Either SAE30 non-detergent engine oil, or Hytran, or Hytran-equivalent is the "right oil."
