Throw-out bearing on an M - is it a problem?
Posted by Slappy on November 11, 2008 at 10:26:51 from (68.221.185.184):
The throw-out bearing I ordered from IH came last week. It looks identical to the one that came out, but when installing it, I noticed that it was packed with a stiff waxy substance. The bearing appears to be pre-greased with the stuff with no means of lubricating it if the wax is removed. The problem is that the wax is so stiff that the bearing can't be spun by hand. Even heating the bearing until it was warm to touch didn't loosen it up.
Is this normal? Will clutch pressure cause the bearing to spin? I'm afraid to put the bearing on until I'm certain that it won't grind the fingers off my new clutch when I use it.
Thanks in advance!
