Worth a try: - Disconnect the input wire from the coil.Take a wire from the battery Negative and hook it up to the same point. Thereby you bypass any drain point. If it works you can leave it that way by putting a seperate ignition switch in the wire. Or you can rewire your current ignition system to a different pick up point. MTF
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
