Re: Carb on F-20 freezing up.
Posted by RustyFarmall on November 11, 2008 at 12:40:34 from (209.152.78.71):
In Reply to: Carb on F-20 freezing up. posted by SproutW on November 11, 2008 at 12:26:51:
What happened is pretty much normal. Humidity and temperature at that magic point and carburetors will frost up. Try wrapping a piece of tin or similar around the carb so that the heat from the engine will warm up the carb also.
