Posted by NDS on November 11, 2008 at 16:30:14 from (64.12.116.73):
In Reply to: clutching issues on H posted by c1802362 on November 10, 2008 at 18:53:38:
If you mean that with tractor idling with clutch out and then you get a little grind when you depress clutch and shift into gear that is a common problem. One easy cure (assuming you have working belly pump) is to pull out lift all lever when you depress clutch and wait couple of seconds and pump will load clutch enough to cause it to release.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
