Re: M coolant drain
Posted by Armand Tatro on November 11, 2008 at 18:10:48 from (98.227.135.78):
In Reply to: M coolant drain posted by freezer on November 11, 2008 at 17:25:49:
If the wing nut is in the right side of the block you can use the engine crank as wrench to remove and replace the plug. Also when/if you replace the plugs coat them with never-seeze on the threads before replacing. Armand
