Posted by J.J. from Afton on November 11, 2008 at 19:45:37 from (139.225.250.243):
In Reply to: gear ratios posted by wegman in mn on November 11, 2008 at 17:46:38:
Well the common way it is done to get all the gear ranges is to have the driving gear mesh with the forth and fifth slider gear. Than once that power is harnessed get it out through the opening where the belt pulley mounts. From there large chains are usually used to drive a shaft running to the front axle. Also youd have to caluclate all you gear and chain ratios to be sure you get corresponding ratios between the front and rear wheels.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
