Re: B275 dash
Posted by JimB2 on November 11, 2008 at 19:47:22 from (99.241.179.24):
In Reply to: B275 dash posted by ShaneGreen on November 11, 2008 at 19:22:28:
Hi Shane, there should be an "L" handle switch to hold down to activate the glow plugs and the indicator should look like the top of a salt shaker. Hold the handle down until the coil behind the salt shake top glows. Warm weather will not require as much glow, the colder it gets the more glow required. Don't hold down to long or you will burn out glow plugs or indicator. They are all wired in series like the old xmas tree lights, one blows and they all don't work.
Good luck
JimB
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
