If a battery is in decent shape but just run down (out of charge) a jump can still get a tractor going but if a battery is really really bad like an internal short, even a jump may not do the trick. Let a shop load test it for you !!
The first thing I would do is remove, clean n wire brush n reattach EACH AND EVERY battery and starter and starter switch and ground cable and connection and with a good charged battery or a jump or both see what happens???
If she still refuses to crank Id do like Jim n others mentioned and check for a mechanically stuck/jammed starter by loosening it and/or rocking the engine n see if it un jams.
If its not jammed and the battery and alllllllll cables n connections are good, next Id suspect either:
1) The starter switch is bad (like if its a stand alone push switch up on the pedestal which you can use jumper cables to by pass jump around)
2) The starters external copper post (under the switch ifffffff it has a mechanical saddle mount right on the starter switch) is worn down
3) Finally if its not stuck and NOT a switch problem and all cables n battery n connections are good, the starter itself may be bad.
If it has any working lights turn them on and observe if they dim way down badly when you try n start it?? If so Id suspect a stuck/jammed starter or a bad starter (like a shorted armature etc). If the lights dont dim down then Id be more suspicious of a staretr switch problem although the starter itself could still be bad like worn brushes..
Check the cables n connections then see if its mechanically stuck/jammed n go from there
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
